no crank when cold
Old Sep 24, 2018 | 07:27 AM
htseat2000's Avatar
Default no crank when cold
I have a 2000 monte carlo that has an odd issue. 190K miles. this has been happening recently when temp gets around 70 or below from sitting over night. go to crank and nothing and when you let go of key the starter will bump. will have to to this anywhere from 2 to 8 times before it actually turns over and starts. no security light, replaced ignition switch last year already. it is not the relay because I switched the relays out. I do have original starter but i don't believe that is the cause. why i say that is because after car is warmed up and I drive it to work, I have no problems the rest of the day. anyone else ever had this issue?
Old Dec 4, 2018 | 08:19 PM
DannNL's Avatar
Default Has this been resolved ?
Same issue over here on my 04. Have you had any luck? Struggling over here with the cold months coming
Old Dec 5, 2018 | 10:13 AM
htseat2000's Avatar
ignition switch was actually the culprit even though I had changed it a couple years ago
Larryj558
Jan 1, 2019 08:32 AM
DannNL
Dec 6, 2018 03:36 PM
ThomasB81677
Jul 6, 2018 02:31 PM
Kooni Holmes
May 14, 2016 11:00 PM
MonteSS2001
Sep 28, 2007 06:51 AM
