no ac or heat... no air period.
Old 05-30-2015, 04:01 PM
scotthartbti's Avatar
Not sure as i've never done it on these cars, but i think its up in the passenger footwell.
You are correct. And they use the stupid weird pattern bolts (forget the name at the moment)... Guess I gotta go digging through my tools.
Old 05-30-2015, 04:28 PM
Probably a torx bit or a security bit, if thats what it is, go pickup a set as i've used mine more often than i thought i would.
Old 05-30-2015, 04:33 PM
Yea... That's it .. Torx... I have some laying around somewhere
Old 05-30-2015, 04:34 PM
I had a 2001 grand Prix gtp prior to this car.. Pretty much the same thing minus the supercharger of course.
Old 06-02-2015, 01:26 AM
If it's anything like my 04, the blower motor wouldn't spin up when you turned it on, and it would come on seemingly randomly. I went through the trouble of replacing the resistor and it still didn't work. Then I noticed that it would kick on whenever I went over bumps, with the car parked I tried tapping the motor side to side and that did the trick, the fan blades were hitting the shroud keeping it from starting up. Try doing that before you replace the resistor.
Old 06-02-2015, 05:14 AM
Thanks for the info. I just spoke with my friend who has been a mechanic for many years and he gave me similar information as far as giving the motor a few whacks once I remove the panel. Was going to try last night, but of course it was pouring the entire time and I don't have the luxury of a parking garage. Hopefully the weather holds off tonight so I can take a look.
Old 06-03-2015, 05:56 PM
Sorry for the late response... Finally got around to checking the blower motor... Took the panel off and located the motor... Left air on and on high... Gave the motor a few whacks... Fired right up. Not sure it'll hold out for long, but at least its working and I know that's def the culprit. Thanks for all the feedback guys.
Old 07-12-2021, 11:47 AM
Default Blower Resistor
[SoundsQUOTE=scotthartbti;664382]I have a 03 Monte Carlo SS with 78,000 miles. Yesterday I turned on the ac and nothing happened. About 5 minutes later it suddenly started working. Today I turn on my car and nothing. I've tried throughout the day and still nothing. No heat or ac... No air at all coming from the vents at any setting or speed. I checked a few fuses and from the looks they are good, but I guess I'm not sure where the main one is that could be causing this? Possible the blower motor took a crap? Any help is appreciated.[/QUOTE]
When the blower resistor goes bad, a total loss of the blower will occur. Take a small rubber mallet and tap the blower motor housing with the AC switch in the on position. This will often pinpoint a bad resistor or a bad blower motor.
marcros
04-07-2015 06:48 AM
#2726
12-09-2011 12:21 AM
siouxcity04montess
06-05-2010 05:49 PM
drewskie043
12-21-2009 08:19 PM
White05LT
11-18-2005 10:03 AM
Quick Reply: no ac or heat... no air period.
