no ac or heat... no air period.
Old May 29, 2015 | 09:32 PM
scotthartbti's Avatar
Default no ac or heat... no air period.
I have a 03 Monte Carlo SS with 78,000 miles. Yesterday I turned on the ac and nothing happened. About 5 minutes later it suddenly started working. Today I turn on my car and nothing. I've tried throughout the day and still nothing. No heat or ac... No air at all coming from the vents at any setting or speed. I checked a few fuses and from the looks they are good, but I guess I'm not sure where the main one is that could be causing this? Possible the blower motor took a crap? Any help is appreciated.
Old May 29, 2015 | 09:49 PM
Maybe these attached fuse box diagrams can help you.
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
File Type: pdf
Old May 29, 2015 | 11:10 PM
Awesome... At least I know exactly what I'm looking at now and don't have to guess... I was looking for something like that. Thank you. Hopefully its as simple as just a fuse. Its way to hot to have the ac not working!
Old May 29, 2015 | 11:15 PM
You are welcome.
Let us know how it all works out!!
Old May 30, 2015 | 12:19 PM
You are welcome.
Yea... Checked all fuses and everything looks good. When I switch it the air on u can here it like its kicking in and when I turn it off u can here it turn off... Just no air.
Old May 30, 2015 | 02:40 PM
ewww sounds like the blower motor has gone south on you But I am not an expert by any means. Hopefully others will give their opinions.
Old May 30, 2015 | 02:43 PM
Yea... That's what I'm pretty sure of. I know the blower motor resister has been known to have issues, but from what I have read it will normally still work on at least one of the speeds if that's bad..
Old May 30, 2015 | 03:51 PM
sounds like blower motor or blower motor resistor.
Old May 30, 2015 | 03:57 PM
From what I've read replacing either of those is a pain because the bolts are hard to get at.
Old May 30, 2015 | 03:58 PM
Not sure as i've never done it on these cars, but i think its up in the passenger footwell.
