Need some help on 03 SS
Old Nov 20, 2012 | 07:16 AM
kingreyna's Avatar
Default Need some help on 03 SS
My friends 03 SS had been randomly shutting off while driving then wouldnt start up untill after the third time. Now it wont completely turn over at all. We thought maybe it was the crankshaft sensor since it would turn off while driving. Well we replaced the sensor behind the pulley but still no luck. The fuel pump is working and fuel is going to the engine. The starter and battery have also been removed and checked and they are good.
We may be thinking since it was an aftermatket sensor maybe that could be the problem. I know MAf sensor are really picky if its aftermarket. Had to mess with that twice. Any way to test the sensors?
Any ideas guys?
Old Nov 20, 2012 | 07:29 AM
If it was the MAF, unplugging it would work.
Sounds like it could be an ignition switch problem
Old Nov 20, 2012 | 04:32 PM
aussiek2000's Avatar
Wont crank at all? BCM or ignition switch problem.
MCSS06
May 29, 2015 08:04 AM
blackmonte781
Oct 3, 2011 01:38 PM
nebstewart07
Jun 19, 2009 08:38 AM
mickey
Aug 23, 2006 05:31 PM
Puppet Master
Aug 15, 2006 07:44 PM
