6th Gen ('00-'05): Need help getting my SOUND to work
Old Mar 18, 2022 | 08:57 PM
Perry buhl's Avatar
Default Need help getting my SOUND to work
Okay so hopefully people still come on this site bc i could really use some help. I bought my monte catt try lo about a month or so ago n its killing me to not beable to listen to any music not even radio. My radio works like the head unit (factory) ut turns on u can change radio station all that turn up the volume, n it says the volume is turning up but i dont hear anything not even a static i checked the fuses there good my amp is good (99%) sure it is but i noticed theres wires ripped out of the harness it almost looks like a red wire with black stripes and a blue wire with white stripes. Is this my problem do i need to get a new harness/adapter n splice all the wires back to together?
Old Mar 18, 2022 | 10:48 PM
Is it still the factory amp? And if wires are pulled out of the factory harness, that is most likely problem #1. The other items I would check is get the pin-outs for the wiring harness to the amp and find out if it has a good ground and if the power connections are actually delivering power properly.
Old Mar 18, 2022 | 11:36 PM
Perry buhl's Avatar
[QUOTE=The_Maniac;728493]Is it still the factory amp? And if wires are pulled out of the factory harness, that is most likely problem #1. The other items I would check is get the pin-outs for the wiring harness to the amp and find out if it has a good ground and if the power connections are actually delivering power properly.
thankyou sm for the reply! Yes its the factory amp. I have a new harness coming tomorrow morning im gonna pit everything in tomorrow ill keep u updated n see if those ripped wires r a problem
Old Mar 19, 2022 | 04:53 PM
Perry buhl's Avatar
Default Fixing sound on 05 monte carlo
Does anyone have the wiring diagram to ALL the wires going to the factory amp in the trunk i need to kno which wire is what i kno the speakers wire i just dont kno any of the other wires going to this amp if anyone could help me out with that id greatly appreciate it
quecat14
Jul 18, 2014 12:44 PM
sixscarlo
Apr 18, 2012 09:30 PM
ctownbandit
Dec 10, 2010 03:19 PM
michael05
Jul 31, 2009 03:21 PM
kweef
May 14, 2008 08:04 PM
