Need help.
Old Jun 15, 2013 | 11:36 PM
2007MonteCarloLS's Avatar
Default Need help.
I cannot really find information on this but when I got an alignment after new tires it was noted I need "rf outer tie rod l/f bearing" <- can someone tell me what this is or guide me to a web page that could tell me? What do you think this should cost?
Old Jun 16, 2013 | 05:59 AM
Here's a thread with some tie-rod information: https://montecarloforum.com/forum/ge...ds-hard-42028/
And left front bearing means the whole wheel hub assembly on these cars. Stick with Timken or ACDelco parts. If you search Wheel Hub Assembly, you will probably find a bunch of how-to threads on that as well.
Doing it yourself can be as cheap as about $150. Having a shop do the wheel hub assembly alone can be about $500
Old Jul 11, 2013 | 09:26 AM
Is this "rf outer tie rod l/f bearing" one problem/one fix/one repair or is it two or what?
If they say this "rf outer tie rod l/f bearing" needs to be repaired, what, to someone like me, that "rf outer tie rod l/f bearing" looks like a foreign language to does it actually mean in terms I may understand?
Old Jul 11, 2013 | 09:35 AM
Right Front Outer Tie Rod (passenger side, front)
Left Front Wheel Bearing (also known as Wheel Hub Assembly on these cars) (driver's side front)
Old Jul 11, 2013 | 12:00 PM
VictoryRedSled's Avatar
Kostya Valerio
15
Jun 14, 2015 09:52 PM
jaydflash
Aug 29, 2014 03:38 AM
00SSsupercharged
Apr 29, 2009 09:45 PM
zk6216
Mar 11, 2008 11:19 PM
mickey
Aug 23, 2006 05:31 PM
