Need help with 01 monte ss
Old Jan 26, 2015 | 06:40 PM
JesseSuede's Avatar
Default Need help with 01 monte ss
Less than a week ago my monte is making squealing noise under the hood. Someone said it's the harmonic balancer going out. I have replaced the pcv valve but that's all. Plus I believe a vacuum problem. While in Park just idling I can take my oil cap off and it'll have a lot of suction on it and when I take it all the way off the engine almost dies and sometimes does. What do I need to do to fix this?
Old Jan 29, 2015 | 06:03 AM
JesseSuede's Avatar
So I took the car to a mechanic and he said that my lower intake gasket is bad. So I finally figured out what's wrong with my car. I hope that anyone that has this problem that this will help.
Old Jan 29, 2015 | 06:08 AM
Sorry I did not see your first post or I would have welcomed you to the forum the other day.
Sorry to hear about the gasket Hopefully it is not too costly.
Anyway, welcome to the forum!!
Old Jan 29, 2015 | 05:43 PM
owens91's Avatar
i would of guessed a vaccum leak, i never heard of a lower intake gasket causing this. but who knows maybe it will fix the issue, welcome to the forum
Old Feb 2, 2015 | 10:15 AM
03SSLE's Avatar
Before spending the money for an intake gasket replacement check your PCV valve.
Old Feb 2, 2015 | 11:46 AM
JC Colon's Avatar
I agree with 03SSLE. Although I have not had this particular issue, I know that if you remove the PCV while the engine is running there is suction. I would think, that if the LIG was bad you would have an oil leak, or a coolant leak, or air being sucked in at the leak location.
Kostya Valerio
15
Jun 14, 2015 09:52 PM
jaydflash
Aug 29, 2014 03:38 AM
rmase182ls
Feb 28, 2011 03:57 PM
00SSsupercharged
Apr 29, 2009 09:45 PM
mickey
Aug 23, 2006 05:31 PM
