Is it my belt tensioner? 2001 monte carlo ss 3.8
Old Mar 18, 2010 | 02:32 AM
jameslinn83's Avatar
Default Is it my belt tensioner? 2001 monte carlo ss 3.8
Ok so I recently started getting a squealing noise coming from under the hood a little while after the car is heated up. I know what a squealing belt sounds like and I am pretty certain thats not what it is. Also because it only really squeals when I let off the gas. When I am cruising down the road or accelerating it makes no noise. This leads me to believe its the tensioner or a bearing in one of the accessories. The car just when hit 165000 so I am not sure it could be anything. Let me know what you think.
Thanks.
Old Mar 18, 2010 | 08:43 AM
MAMONTE's Avatar
Its very possible that its a pully bearing. But to start with the simple stuff, I would put some belt dressing on your belt, and see if the problem goes away, maybe it is just a squealing belt!
Old Mar 18, 2010 | 08:12 PM
Justin Knight's Avatar
Default Belt dressing is evil
try taking the belt off first and starting the engine briefly if the noise is gone its one of the belt driven parts. to determine which one try spinning the pulleys one by one to listen for any noise. see if this helps but if you put belt dressing on it actually damages the belt and can make the noise worse, i know that sounds wrong but trust a pro on that one.
Old Mar 18, 2010 | 08:28 PM
mak330's Avatar
true that, a new belt cost like 26 bucks. i would try that b4 the dressing. all you need is a long breaker bar and 10 mins. follow the directions that are in your face while looping.
Old Mar 18, 2010 | 08:56 PM
nemesis's Avatar
2009 Monte Of The Year
x2 i heard about that too
tarintino07
Dec 30, 2014 04:13 PM
wnmech
Nov 23, 2008 05:57 PM
24_48Fan
Mar 21, 2007 10:01 AM
montejass
Sep 1, 2006 06:16 PM
montejass
Aug 7, 2006 09:32 AM
