My 01 is in a security coma and my belief system is destroyed
I installed a new Passlock sensor and key cylinder with a switch I knew was good and as I expected, there was no change. Without a Tech 2 to confirm, I'm planning a BCM replacement. Better to do it now than 1000 miles from home.
SUCCESS! I went to Pick N Pull today and got the bcm and radio out of 2000 SS ($50 total) and my car is running and all systems are working, except the airbag light is on. I expected that since I have the side impact airbag in my seat that wasn't available in 2000. Now I know it is the bcm and I will have a working backup set of everything but the pcm and ecm when I get my new ACDelco bcm programmed in the near future. Also got a nice instrument cluster cover and and a correct 2nd design factory amp. After doing the security reset procedure and actually seeing the flashing security message, it started immediately and ran smooth. One old car problem resolved.
6th Gen ('00-'05): Security light won't stop flashing
Bwill414
10-05-2019 08:56 AM
6th Gen ('00-'05): Battery, security, service vehicle light
83 Futura
09-10-2017 09:09 PM
PCWeber
01-12-2015 08:38 PM
