7th Gen ('06-'07): Fan runs non stop
Old Jun 4, 2021 | 07:23 PM
angela w's Avatar
Default Fan runs non stop
we hen i start my car the fan automatically turns on and when I shut car off fan turns off but the temp gage always runs in the middle no higher. When I pop hood it feels hot so my question is, is it possible my car is running hotter than my gage says and should the fan run all the time
Old Jun 4, 2021 | 07:54 PM
Wayne67vert's Avatar
The fan runs when the A/C is on. Turn off your A/C and it should turn off.
Old Jun 4, 2021 | 08:04 PM
angela w's Avatar
It runs like this with ac off
Old Jun 4, 2021 | 09:44 PM
a quick check for temperature is to use a laser thermometer. Check the temp on the thermostat housing, the hoses and radiator.
Old Jun 7, 2021 | 04:54 PM
USPatriot1963's Avatar
Default Coolant Temperature Sensor
Sounds like the typical symptoms of a bad coolant temperature sensor. It is located under the thermostat housing and to the right of right engine torque strut.
Mgw2k20
May 5, 2021 06:11 PM
claydoh
Jul 8, 2019 07:26 PM
thewhitestcarlouknow
May 6, 2014 08:48 PM
Ryans93'
Jul 11, 2012 11:13 AM
carcrazi101
Mar 17, 2012 10:16 PM
