6th Gen ('00-'05): Battery, security, service vehicle light
Old Sep 10, 2017 | 03:15 PM
83 Futura's Avatar
Default Battery, security, service vehicle light
I have been have been having intermittent issues with battery, security and service vehicle soon lights popping in the message center when I first start my car. The car doesn't have issues starting or turning off during driving. It usuaply happens when I have my door open while I put the key in the ignition , but it has happened when my door is closed. When I put the key in the ignition instead of making the normal chiming noise it makes a weird chime then when I start the car the three lights pop up. Is it possible that it's the ignition cylinder? Any thoughts or ideas?
Thanks,
83 Futura
Old Sep 10, 2017 | 09:09 PM
plumbob's Avatar
That's most likely the ignition lock cylinder, ignition switch housing, weak battery, or BCM, probably in that order.
