Monte SS INTRUMENT CLUSTER, FIT A 2004 Impala ?
Old Sep 9, 2012 | 10:57 PM
MJClemm's Avatar
Default Monte SS INTRUMENT CLUSTER, FIT A 2004 Impala ?
Hello guys, do you know if a Monte Ss (6th gen) will fit a 2004 Imala ? It has the regular gauges, gas, speedo, etc.. But I want to put the SS gauges in it... I have a Gauge cluster from a 6th Gen and would like to install it.. Just wondering if I do (if the wire connection is the same) will the oil, temp, tach, speedo, amp, temp etc work? Thanks for the help... Mjc...
Old Sep 10, 2012 | 06:12 AM
As I understand the Monte and Impala clusters (base and SS) are the same models between the cars. I've read in the past you can drop the SS Cluster in but there is an issue that the oil pressure gauge does not work.
I know in my '94 Grand Am, that was resolved by switching the oil pressure switch for the sending unit, but I believe others have said on a new car like the Impala you mentioned there's more to it.
Old Sep 11, 2012 | 04:43 AM
MJClemm's Avatar
Thanks for the input..mi think I'll try it then, I didn't want to install it and have fuses and stuff pop all over the place.. Lol.... Thanks again.. Mjc...
Old Sep 11, 2012 | 05:16 PM
They're identical, except for the Impala LS cluster, it's a bit different, but that's it.
They should fit just fine.
Old Apr 27, 2015 | 06:20 PM
bigcoop_03ls's Avatar
I know this topic has been talked about to death,but my question is ,even though the oil pressure guage doesn't work on SS to LS swaps,is there still some sort of warning light connected to it like the ls cluster? Thanks.
Monte2000
Apr 20, 2013 04:56 PM
MJClemm
Aug 1, 2012 12:30 PM
icon801
Dec 18, 2011 06:40 PM
brewcitymc
Nov 24, 2011 10:39 AM
TETCarlo
Oct 11, 2010 12:25 PM
