Monte SS INTRUMENT CLUSTER, FIT A 2004 Impala ?
Hello guys, do you know if a Monte Ss (6th gen) will fit a 2004 Imala ? It has the regular gauges, gas, speedo, etc.. But I want to put the SS gauges in it... I have a Gauge cluster from a 6th Gen and would like to install it.. Just wondering if I do (if the wire connection is the same) will the oil, temp, tach, speedo, amp, temp etc work? Thanks for the help... Mjc...
As I understand the Monte and Impala clusters (base and SS) are the same models between the cars. I've read in the past you can drop the SS Cluster in but there is an issue that the oil pressure gauge does not work.
I know in my '94 Grand Am, that was resolved by switching the oil pressure switch for the sending unit, but I believe others have said on a new car like the Impala you mentioned there's more to it.
MJClemm
Aug 1, 2012 12:30 PM
