monte shuts off while in park
Old Mar 18, 2011 | 12:59 PM
heartbeat's Avatar
Default monte shuts off while in park
i bought a 05 monte carlo lt about a month ago and sometimes while im in park the engine will just shut off. happened two times already. anyone know what could be going wrong?
Old Mar 18, 2011 | 01:06 PM
Does it slowly die? Like it idles, then the RPMs drop to about 4-500 then it kills?
Try to give it gas the next time it does that and if it keeps the car alive check out your idle air control valve (IAC) on your throttle body.
Old Mar 18, 2011 | 01:10 PM
heartbeat's Avatar
i think so i never checked. but on average where should my car be idling? its under the 1 when idling.
Old Mar 18, 2011 | 01:23 PM
Should idle around 800. I know on cold days my idle can jump up to 1100 because of the denser air but lowers when the car gets warmer.
Old Mar 18, 2011 | 01:33 PM
heartbeat's Avatar
if it is IAC is it easy to fix?
Old Mar 18, 2011 | 01:36 PM
You'll need a T-20 Security Torx bit and a new IAC valve and should take about 5 minutes to swap out.
JigJig
Dec 15, 2020 02:28 PM
montecowlo
Dec 1, 2014 10:23 AM
b1chmonkey
Feb 16, 2014 10:25 PM
LuLuBella26
Sep 17, 2013 05:06 PM
kody02ss
Dec 28, 2011 12:01 AM
