Monte Carlo 2000
Old Apr 1, 2014 | 08:29 PM
Mary B's Avatar
Smile Monte Carlo 2000
Hi All
I have a question? Does anyone know where the door drain hole would be in a 2000 Monte Carlo. My door is full of water and I don't know how to drain it thanks Mary B.
Old Apr 1, 2014 | 08:38 PM
Hi Mary..
Welcome to the forum...
In answer to your question...
If I am not mistaken....There are drain holes in behind the rubber trim at the bottom of the door There obviously clogged with pollen dirt etc....
Not knowing how handy you are with a vehicle.... Pull the door trim loose from the bottom of the door (being careful to not damage it) then take clear the drain holes so the water can drain out... Then replace the doors rubber seal and it should solve your problem...
Worse case scenario...
Drill a small hole in the bottom of the area where the water is contained and allow it to drain that way.
I'm sure someone else will chime in with other advice/ideas...
Thanks for joining the MCF Family..
Were here to help.
Old Apr 2, 2014 | 05:59 AM
turbo monte's Avatar
I second what stumpmi said
Old Apr 2, 2014 | 06:27 AM
03SSLE's Avatar
Actually, you don't need to remove the weatherstrip. The drain hole is located below the weatherstrip in the lower rear corner of the door. It is elongated and it takes something small (like a bristle from a whisk broom) to slide into it and clear the clog.
billyp35
Feb 1, 2007 08:00 PM
TGAbreu
Dec 9, 2006 10:31 PM
Mike
Aug 29, 2006 10:33 PM
00pacecar
Jul 6, 2006 02:18 AM
te100
Jan 29, 2006 05:31 PM
