6th Gen ('00-'05): Missing bracket?
Missing bracket?
Hey folks,
I'm trying to undo all of the previous owner's work on an '01 that I pulled form the dead. I've started to replace all of the brackets and fasteners that appear to be missing but can't tell about the harness that runs off the engine to the junction block (connector C112 I beleive). Looking at other images of the 3800 engine in the MC it appears that there should be a bracket or something for the harness to attach to before it passes over the space between the belt and the junction block but I can't find anything in the literature. So, please take a look a the attached picture and let me know what your thoughts are, much thanks in advance.
Tony
Tony
Yes. You can see a clip holding the wiring harness together. That clip should have piece (assuming it did not break off) to attache to a small metal bracket that is bolted in the far right of the upper intake (the bracket shares a bolt that has a short stud coming off the head of the bolt, the bracket sits on the stud and then a nut holds it all together). If I can, I will try to get a pic later.
6th Gen ('00-'05): Does anyone know what this connector is?
troj84
04-03-2017 04:04 PM
6th Gen ('00-'05): What does this harness connect to?
rgant_19
02-23-2014 12:24 PM
