6th Gen ('00-'05): Missing bracket?
Old Aug 31, 2022 | 11:35 AM
tpisellijr's Avatar
Default Missing bracket?
Hey folks,
I'm trying to undo all of the previous owner's work on an '01 that I pulled form the dead. I've started to replace all of the brackets and fasteners that appear to be missing but can't tell about the harness that runs off the engine to the junction block (connector C112 I beleive). Looking at other images of the 3800 engine in the MC it appears that there should be a bracket or something for the harness to attach to before it passes over the space between the belt and the junction block but I can't find anything in the literature. So, please take a look a the attached picture and let me know what your thoughts are, much thanks in advance.
Tony
Old Sep 2, 2022 | 12:52 PM
Glen01SS's Avatar
On mine, there is a clip that plugs into the bottom of the support brace that goes over the battery to the core support
Old Sep 2, 2022 | 01:54 PM
tpisellijr's Avatar
Thanks for the reply. I have the one above the battery as well, though it's mangled, but I'm more interested if there is anything near the ignition coils?
Tony
Old Sep 8, 2022 | 01:11 PM
Yes. You can see a clip holding the wiring harness together. That clip should have piece (assuming it did not break off) to attache to a small metal bracket that is bolted in the far right of the upper intake (the bracket shares a bolt that has a short stud coming off the head of the bolt, the bracket sits on the stud and then a nut holds it all together). If I can, I will try to get a pic later.
troj84
Apr 3, 2017 04:04 PM
honk
Apr 3, 2014 12:30 AM
rgant_19
Feb 23, 2014 12:24 PM
Radagast the White
Nov 15, 2013 07:18 PM
Dam20735
Sep 22, 2012 01:22 PM
