Many Issues Mechanic friend says MAF- HELP PLEASE
Old Jan 6, 2012 | 05:12 PM
Was AutoZone able to tell you what the "Service Engine Soon" code is about? That could be the key to what is going on.
Old Jan 7, 2012 | 09:55 AM
anagy007's Avatar
Yes, Im sorry I didn't post that. Autozone said the code was P0102
Old Jan 7, 2012 | 10:40 AM
03SSLE's Avatar
The P0102 code would indicate low voltage at the MAF sensor. As previously mentioned, it can be removed and cleaned. Make sure the electrical connector is clean and tight when you reinstall the sensor. If cleaning the sensor doesn't resolve the problem check for air leaks and (using a multimeter) backprobe the electrical connector and check the voltage. If no air leaks are found and the voltage is good replace the MAF sensor.
kevin8629
Sep 9, 2013 10:53 AM
joshft91
May 21, 2012 02:09 PM
mairj40
20
May 1, 2012 08:38 PM
Drifter
Dec 16, 2009 04:49 PM
BeachBumMike
Mar 3, 2007 02:00 PM
