Lower ball joint bolt
Old Jun 9, 2019 | 01:23 AM
dbaker88's Avatar
Default Lower ball joint bolt
I have a 2001 Monte LS. I recently replaced both my lower control arms. They came already assembled with new lower ball joints. The original ball joints were attached to the control arm with 3 rivets which were flush with the control arm. The new ones, however, are attached with 3 bolts and one of the bolts hits the bottom of the steering knuckle when i turn the wheel. Is there something else that could be messed up, causing the bolts to hit? Can i just take an angle grinder and grind the bolt down? Theres about 1/3 inch of extra thread and i only need to take off maybe 1/8 inch. Would this be safe?
Old Jun 9, 2019 | 06:48 AM
volkerc's Avatar
As long as you only shorten the threaded side of the bolt shouldn't be a problem. Keep checking the nuts after a while they tend to come loose.
Old Jun 9, 2019 | 07:13 AM
The bolt head should be on the top of the control arm and the threads and nut on the bottom. If this is not how the new arms are, I would simply remove the nut/bolt set up one at a time and correct it.
Old Jun 9, 2019 | 10:12 AM
dbaker88's Avatar
@ Maniac
For whatever reason the new one came with the bolts the other way (bolt head on bottom and threads on top) which seems ridiculous now. Lol
Im going to put the threads on bottom like you said. It shouldnt hit after that.
I cant believe i over looked the most obvious solution. Lol
THANK YOU
Old Jun 9, 2019 | 10:26 AM
No problem. Sometimes the easiest answers are right in front of us
We have all been there! Hope this is a quick and easy fix for you.
JC Colon
Feb 23, 2015 05:53 AM
zell
Dec 5, 2013 09:40 AM
monte67
FWD Tech Guides '95-'07
Jan 28, 2012 09:52 AM
Gib
Dec 30, 2010 12:14 AM
crzy1051
Jul 11, 2010 11:56 PM
