Low Coolant and Temperature Gauge problem
Old Apr 14, 2008 | 11:32 AM
SmokeytheBear75's Avatar
Default Low Coolant and Temperature Gauge problem
My low coolant light has been coming on and staying but I have coolant in there. My temperature gauge is also acting funny. When my car warms up, it goes almost all the way to the red area and then goes back to where its suppose to be. Also, when I turn on the heat, it just blows cold air. Any help would be greatly appreciated. Thanks
Old Apr 14, 2008 | 11:52 AM
rysZ34's Avatar
Default RE: Low Coolant and Temperature Gauge problem
I would check your thermostat and then after replacing that, check to see if there is any air in the system.
Old Apr 14, 2008 | 01:21 PM
98monte's Avatar
bleed the system.. that's what mine done that sounds like the problem. anytime you add new coolant you need to bleed the system.
Old Apr 14, 2008 | 01:24 PM
kweef's Avatar
bleed the system first...then check ur tstat and your coolant sensor, kinda sounds like the sensor to me but ive had the temp gauge problem and it was a $12 fix
Old Apr 15, 2008 | 08:21 AM
v8_Killa's Avatar
well.... i have never been in/seen amonte or impala that did nnot have the low coolant or tire pressure light so dont worry i think the cars just like it that way also did anyone find a fix for the turn signal problem it works when it wants to
dwebster25
Jul 8, 2015 08:10 PM
dragknt
Nov 27, 2012 08:44 AM
dmfonline
Dec 18, 2010 09:07 AM
RussellUCF
May 28, 2008 09:43 AM
hckygoalie31
Aug 28, 2007 06:44 PM
