coolant temperature sender
Old Dec 17, 2010 | 02:56 PM
dmfonline's Avatar
Default coolant temperature sender
No movement on the temp gauge and the electric fan will run after car is turned off. From reading posts it sounded like the coolant temperature sender. Changed it,and same condition. Getting good heat out of the vents and all else seems normal. Fan will run just for a few minutes after shutting off motor. Thanx-Don
Old Dec 17, 2010 | 10:00 PM
blackmcX2's Avatar
Check what codes are being shown. If it shows a coolant code my guess would be the T-stat. Had a similar problem with the 01. Temp gauge started acting up, changed the temp sending unit hoping that was the problem. Wasn't. Then the A/C quit working. Turned out thr T-stat was stuck open. Engine was'nt reaching proper temp. so computer went into default. Changed the T-stat and that solved both problems.
If this isn't the problem, then it may be in your instrument cluster. Recently went thru that with the 04, but I got lucky on that one.
Old Dec 18, 2010 | 09:07 AM
dmfonline's Avatar
Thanx- Going to try another sender(you never know) AND the thermostat.
dwebster25
Jul 8, 2015 08:10 PM
dragknt
Nov 27, 2012 08:44 AM
SmokeytheBear75
Apr 15, 2008 08:21 AM
smolek37k
Dec 1, 2007 07:08 PM
smolek37k
Nov 4, 2006 04:36 AM
