6th Gen ('00-'05): Low beams not working with high beams
Old Nov 24, 2021 | 04:09 AM
Calvin228's Avatar
Default Low beams not working with high beams
I’ve got a 01 ss recently upgraded to led headlights and noticed that my low beams cut out when I switch to high , is this normal? Haven’t really paid it much attention until switching over to the led bulbs. Sadly my high beams are week by their self or I wouldn’t worry about it … I can see best when I hold the switch to where both are on but after I pull the switch all the way back to just high beams it’s depressing lol . How do I fix this also worth noting I also changed out the the headlight assembly’s as well could it be a wiring issue in the new headlight assembly?
Old Nov 24, 2021 | 08:41 AM
Thats how they work. Lows turn off when you turn on brights. @The_Maniac would be the one to contact for advice on what you want to do if you dont want to hold the lever.
Old Nov 26, 2021 | 11:05 PM
Since the Monte has separate bulbs for low and high beams, this is typical for many GM (and possibly other cars) to only operate one bulb type at a time. I know for certain year Silverados, there is a mod for "all lights on" when activating the high beams (it is all the high and low bulbs and the fog lights). I suppose you could do a mod similar with the Monte (it would take figuring out the areas to jumper with diodes).
When switching to LED bulbs for your high/low beams, I don't feel it is necessary. I switched the high and low beam bulbs to the units I listed below. To help avoid blinding on coming traffic, I even tilted the headlights to point down just a bit. You really cannot tell a difference from my high and low beams. They are crazy bright and the light broadcasts out for what seems like forever! Only reason I changed my high beam bulbs, the DRL using the high beam at low power, I wanted a clean "all LED" look. Downside, the car reports "high beam out" because of how the LED bulbs are detected (if I knew a high beam bulb that did NOT generate a "high beam out" when I start the car, I would consider switching out, but I have not looked into it).
Low beam 9006:
Amazon Amazon
High beam 9005:
Amazon Amazon
sparkyallen1
Oct 14, 2019 10:10 AM
daves92camaro
Mar 26, 2016 09:17 PM
Helldorado
Oct 28, 2015 07:26 PM
svzpt71
May 11, 2015 06:30 PM
ramos87ss
Jun 5, 2009 08:25 AM
