L67 swap
Old May 5, 2012 | 01:37 AM
oscar sanchez's Avatar
Default L67 swap
been a couple weeks all been good but i got a P481 code any common probs and solutions? any help would be apreciated i also need to know if my original 3400 series fuel pump will work with the L67 i notice the car is fine but would it run better with a walbro 255?
Old May 5, 2012 | 01:51 AM
2003L67SS's Avatar
p0481 is a fan circuit 2 malfunction code... i've had issues with mine, replaced twice in a month now, first ones were 186000 mile stockers so no big deal, last set was a month old dorman set that locked up and caused me many headaches, my new set is just another pair of dorman's with a lifetime warranty
you can check the fans by hand with the car off and key off, just spin them by hand and listen for roughness and make sure they both spin freely, if both spin free you should check your fan circuit 2 fuse, its in the lower fuse block under the hood.
Old May 5, 2012 | 02:07 AM
cool thanks man
Old May 5, 2012 | 02:09 AM
2003L67SS's Avatar
cool thanks man
no problem
and fuel pump wise, i wouldn't worry too much about it, a walbro is never a bad idea though.
i'm more biased toward aeromotive myself but walbro's are everywhere and work very well
Old May 5, 2012 | 02:23 AM
will it improve throttle response or performance or is it just one of those things that people buy just because?
Old May 5, 2012 | 02:37 AM
2003L67SS's Avatar
it's just a safety thing, i just got a stock pump for an 05 S/C SS and dropped it in, performance won't increase unless you're running lean right now which would throw a code
Old May 5, 2012 | 05:14 PM
nitehawkjcb's Avatar
Your stock pump SHOULD be enough, but when you start commanding more and more fuel, you will need to upgrade.
I have a Walbro with less than 1000 miles on it if you're interested just PM me.
bumpin96monte
47
Jun 20, 2019 10:16 AM
rohanna
Apr 17, 2009 12:17 PM
Cowboy6622
Dec 15, 2007 10:40 AM
chgs15
Feb 2, 2007 05:02 AM
roadshoptuner
Aug 2, 2006 12:53 AM
