Dashboard lights
Old Jan 24, 2012 | 08:51 PM
joeo's Avatar
Question Dashboard lights
I think I have a photo cell working in reverse controlling my dash lights. When it gets dark they go out during daylight they work but I cannot find it to change it. Any help would be appreciated.
Old Feb 12, 2012 | 10:02 PM
villige1's Avatar
You may look at the dimmer on the head light switch. Mine was bad.
no dash lights at night only in daylight.
Easy it's behind the fuse door on the drivers side.
Old Feb 13, 2012 | 08:36 PM
joeo's Avatar
Default Dash Lights
Thanks alot I ll look into it tomorrow i really appreciate your help this has been a problem for some time
Old Feb 14, 2012 | 07:05 AM
villige1's Avatar
Your very welcome. Help is a good thing now days..
You may see your shifter select lights on the cluster. I think thats all I had working.
Are there any other lights not working?
Old May 5, 2012 | 07:52 PM
Lindamae55's Avatar
I have the same problem. Dash lights in the daytime and no dash lights at night. It started with the radio lights turning off. Then the dash lights got dimmer and dimmer until they shut off completely (within a few days). If I use the manual headlight switch during the daytime, the headlights etc all come on and the dashlights work. Only at night is there a problem. I'm not sure if it's the auto sensor cell or the headlight swith itself. All other headlights, turn signals etc work fine.
RasCricket
Nov 30, 2013 08:55 AM
bfearr
Jul 28, 2013 08:55 PM
spiknek
May 9, 2011 11:57 PM
cjbots
Jan 20, 2011 12:30 AM
96MonteCarloZ34
Jul 29, 2010 05:30 PM
