6th Gen ('00-'05): Kaboom!
Old Jan 9, 2019 | 09:49 AM
Partshunter's Avatar
Default Kaboom!
Hello again!
turned the key to start on wifes 2000 Monte Carlo and blew the upper intake to smitherines.
Never seen anything like it.
So, I'm thinking there had to be fuel/fumes present inside plenum. Leads me to think something's wrong with fuel regulator.
Looks like I'll need Injectors, Fuel reg., Map Sensor, EGR valve (this was stuck in the open position so maybe its the culprit?), Upper Intake Plenum , Gasket Set.
Anyone know about thos happening? First for me!
Old Jan 9, 2019 | 01:41 PM
Smile I have seen this indicated before
Originally Posted by Partshunter
Hello again!
I have seen this indicated before by a few MC owners Makes a mess for sure. here is a link for you to look at and there are videos and all sorts of info here.
https://www.google.com/search?source...30.tsMXPzy5kBk
Old Jan 9, 2019 | 05:17 PM
Most likely a failed fuel pressure regulator, its a known happening with the N/A 3800.. Should be fixable tho.
Old Jan 11, 2019 | 10:24 AM
Skatulaki's Avatar
My 2002 DE LE, when I got it had a intake blown apart, everybody has told me Fuel Pressure Regulator, however mine has set so long before I got it that the
top end was seized up, I have not yet got mine back together to know, hopefully you didn't put the "Black box" in it, mine had a "Black Box" wired in that made it run rich
and carbon everything up, and its taken some time to clean. Be sure to check your wires, sometimes the exploding Intake causes fires ( like mine) and burns some wiring.
Old Jan 11, 2019 | 10:57 AM
So what did you find out ?
Old Jan 12, 2019 | 05:53 PM
Skatulaki's Avatar
You asking me ? or Parts Hunter? I don' have any idea on mine, just started putting it back together, and I'll probably never really know as I intend to replace all the possible culprits along with changing the intake to the Pontiac aluminum L26 intake so that can't happen again.
SteveL
Feb 21, 2017 03:19 AM
KKrueger24
Aug 30, 2016 10:06 AM
matthewsutton
Oct 23, 2014 10:12 PM
CBroadfoot
Jul 24, 2014 04:02 PM
artlawton
Aug 7, 2011 08:53 AM
