intereor fan not working
Old Aug 8, 2011 | 09:21 AM
monte07's Avatar
Default intereor fan not working
ok i had to fix the regulator to bring in and to resurculate air in the cabin. two weeks have passed now the fan is not working. i forgot where the relay is for it is is it fan relay2 or three i also replased the two fuses. is there another fuse i checked the conection and every thing i took apart to check the conection on the fan it is still conected
Old Aug 8, 2011 | 04:49 PM
80sselky's Avatar
I'm not sure where the relay is located on your specific monte but I would check the fan switch and the blower motor resistor.
Old Aug 9, 2011 | 01:33 PM
monte07's Avatar
ok i just got off of work yesterday i found out that there is no relay for the fan only a resistor switch and the fan the switch is the most expencive of the three. the switch is over 278. i ran a volt meter to the wires to the resistor it is getting power as well as the fan. what i mean is i hooked back up the wires to the resistor and there is no power coming to the other end of the wires that conect to the fan well that is going to be a 98-100 dallar fix
Old Aug 9, 2011 | 01:38 PM
monte07's Avatar
i tryed to take out the resistor to get the new one and there is a tab looking thing on one end and a 7/32 bolt on the other it is not the type that holds trim on it looks like some thing i dont know how to describe. i have to figure it out i put in a new fan because it was making noise and i was getting erotated with the noise i should have replaced the resistor first but i replaced one broblem that probably caused anouther
Old Aug 28, 2011 | 08:01 AM
monte07's Avatar
ok i broke down and took it to the dealer they are at a loss on finding why the intereor fan is not working they are going to have it for a while i hate not having it.
gmartinez93
May 11, 2015 10:45 PM
NYGiantsfan
Aug 15, 2013 07:43 PM
jhbasse
Jan 15, 2013 06:39 PM
daves92camaro
Apr 24, 2011 02:41 PM
cornerview
Sep 17, 2010 02:49 AM
