Brake Problems - Master Cylinder or Power Booster??
Old Aug 28, 2011 | 12:50 PM
qzack1's Avatar
Default Brake Problems - Master Cylinder or Power Booster??
Working on a 1998 Chevy Monte Carlo 3.1L. The problem is the brake pedal is pressing all the way down to the floor and pretty much hits the point of scary when attempting to stop. I have checked the valve going into the power booster and it has vacuum pressure going through it. The fluid level doesn't appear to be low and I found no signs of leaks in the master cylinder, lines, or calipers. The research I have done points to it either being a bad power booster or a bad master cylinder. I have also found alot of conflicting points in my research; mainly in the symptoms of those items going out. Most said the power booster going out will cause a very stiff pedal. Others said it would cause the pedal to hit the floor with minimal stopping power. Most info i have found on the master cylinder going out says it will drop to the floor and have minimal stopping power. Any advice out there that can help me figure out which is the problem? or where to start?
MonteMonkey
Oct 15, 2014 03:58 PM
maxwell4
Sep 27, 2012 12:52 PM
Doozer
Jan 19, 2012 02:04 AM
johnm
Jan 10, 2011 02:16 PM
heinzp87
Nov 9, 2010 03:16 PM
