fan speed 1 and 2 not working
Old Nov 14, 2009 | 11:05 PM
daves92camaro's Avatar
Default fan speed 1 and 2 not working
i noticed that on my 03 on the way to work tonight...3,4 and 5 perfect just 1 and 2 not at at all on my heater controls fan speed..and ideas?
Old Nov 15, 2009 | 08:42 AM
aussiek2000's Avatar
Most likely the blower motor resistor. You will most likely also need the pigtail that plugs into it because they melt and then cause high resistance at the plug in point on the new resistor.
Old Nov 17, 2009 | 11:10 AM
RocknSS04's Avatar
yup..
Old Nov 17, 2009 | 11:37 AM
Can't it also just be a simple vacuum problem?
Old Nov 17, 2009 | 01:46 PM
They don't run on vacuum anymore. Everything is electric.
Old Nov 17, 2009 | 02:49 PM
RocknSS04's Avatar
it's the resistor block. Make sure you get the HD one, that is encased in epoxy. There are some that are not.
Old Nov 17, 2009 | 10:39 PM
where is this resistor block located...by the fuse block?
Old Nov 18, 2009 | 02:21 AM
just did a search..its under the dash..yucky
Old Nov 18, 2009 | 02:47 AM
Wilco's Avatar
Now you can practice your contortionist moves and see how flexible you really are. LOL, I hate working under the dash!
Old Nov 23, 2009 | 11:20 PM
jibb3r's Avatar
Where would one find an HD resistor? I was going to pick one up at AutoZone for $30 dollars. They have another that's $40 dollars...?? Or does the one you speak of come from the stealer? Being the mechanic that I am not, I wouldn't know the difference either way.
That's on my list for this week. I can't take my eyeballs drying out of my head, with a heater that only blows on 3-4-5.
