im stumped and out of money
Old Dec 25, 2006 | 02:25 PM
InTheIROC's Avatar
Default RE: im stumped and out of money
Those are not the only things that can cause a misfire. Incorrect compression in that cylinder (4 I assume since they said Injector number 4) can cause a misfire as well as dirty valves or a bad ignition coil. Incorrect fuel pressure can also cause a misfire, but that would not likely be isolated to one cylinder. The O2 simulator wouldn't have an effect on a misfire code because that gets installed after the cat and is used to measure cat efficiency. I'm not sure which motor is in the 97 Z34, but if you can swap coils, I would do that and see if the misfire code changes to a different cylinder.
Old Dec 27, 2006 | 12:13 PM
97z34's Avatar
the plugs, wires, and coils are all good.
Old Jan 3, 2007 | 08:47 PM
97z34's Avatar
i got the O2 in today and marked another sensor off the list but still have so many left. IAT, IAC, etc etc. or even the PCM idk i might just sell it and buy and older camaro, im tired of OBII cars they suck.[:@]
sixscarlo
21
Mar 3, 2013 01:29 PM
STUMPMI
Oct 12, 2012 05:23 PM
shaneb66
Apr 19, 2012 10:38 PM
rupert1027
May 29, 2009 01:13 PM
mudbog42
Aug 16, 2008 12:34 AM
