04 Monte has me stumped
Old Apr 13, 2012 | 11:43 AM
shaneb66's Avatar
Default 04 Monte has me stumped
I have an 04 Monte with a 3800, over the last 3 or 4 years we have had to change the Ignition control module 3 times. Every time we changed it the old one always tested good, but changing seemed to fix the problem until now. it will start up and run for 3 to 4 min and then just shuts down. I have changed everything i could think of except the ECM & BCM. any suggestions
Old Apr 13, 2012 | 11:55 AM
nitehawkjcb's Avatar
Could be:
Crank sensor
Cam sensor
Wiring short
PCM
Ignition switch
Old Apr 13, 2012 | 01:35 PM
03SSLE's Avatar
Since manipulation of the control module (and the wiring connector) seems to "fix" the problem I would suspect a dirty/bad connection in the connector or possibly a broken wire in the harness.
Old Apr 19, 2012 | 10:38 PM
Years ago I was chasing an intermittent problem down where my Grand Am would go from running fine to mis-firing and the computer just dumped more fuel to compensate. By RANDOM chance, found the problem to be a bad coil (I was inspecting, wiggling wires and such while the car idled, found placing my hand on one coil, I could make the problem come and go). Replaced it with a known good spare, never looked back.
If testing the ICM comes back good, odds are it's coincidence as to why the problem "goes away". Could be as simple as a bad wire.
sixscarlo
21
Mar 3, 2013 01:29 PM
STUMPMI
Oct 12, 2012 05:23 PM
rupert1027
May 29, 2009 01:13 PM
mudbog42
Aug 16, 2008 12:34 AM
97z34
Jan 3, 2007 08:47 PM
