6th Gen ('00-'05): Ignition switch melted wire
I have a 04 ls that has been giving me passlock problems. I got a new ignition switch put it in and when u turned the key it started smoking. Found out it melted a wire in the harness.
What is the wire for and did this harm anything else?
Symptoms are no fuel pump or crank when turn key. I've tried the relearn countless times no luck.
I've looked thru my diagrams and didn't have it anymore. You can google search the switch and find it that way if nobody else chimes in , but regaurdless you have to repair the wire so follow it to the next junction and look for issues. Good luck
Mod Guide: How To: Bypass Passlock Security
Nocturnx
FWD Tech Guides '95-'07
25
Jan 15, 2026 05:26 PM
4th Gen ('81-'88): Isolater issue.....81 MonteCarlo
efaz43
Sep 17, 2015 04:27 PM
