4th Gen ('81-'88): Isolater issue.....81 MonteCarlo
Old Aug 29, 2015 | 02:19 PM
efaz43's Avatar
Default Isolater issue.....81 MonteCarlo
My Isolater calls for a separate wire connection to a 20a ignition key circuit. The Isolater is located just above the main battery (upper driver side front). What/where is the easiest location to an ignition keyed circuit. i was thinking that the wire to my built in reguater that connects to my alternater would do but I am wary to tap in to the wire. Where on the fuse box can I connect to? As an option...do I have to go off the ignition switch itself? I researched that the pink wire of the ignition harness feeds the solenoid, so it must be a momentary switch, right. Is it dangerous to run into this wire....I appreciate any advice....Ed
Old Aug 31, 2015 | 07:20 PM
Places on the fuse box that are directly influenced by the ignition switch are (according to the Chilton's manual diagram) the choke(25A), power window, a/c htr(25A), radio(10A), and wiper(25A). the power window does not have a rating listed. it just says CB and I have no idea what that means.
Old Sep 1, 2015 | 07:42 AM
Barbara:
CB= circuit breaker..
Or
An actual CB radio...
It all varies with options of your particular vehicle.
Some vehicles came with a built in CB via the radio.
But on separate power circuits/fuses.
Old Sep 1, 2015 | 09:22 AM
Thanks David.
Old Sep 1, 2015 | 12:00 PM
efaz43's Avatar
Default Should I use a relay from the ....
Fuse Center 20a on/off ignition key circuit to the isolater, 7 ft span and what gage wire?
Old Sep 1, 2015 | 07:55 PM
efaz43's Avatar
Default Isolater bottom line
I got a Add a Circuit fuse tap and will place it in the "Radio"fuse slot on the car's fuse block which is not being used. Previously, I ran wiring to my radio separately. I will use 12 gage wire from that and a relay to get to the Isolater. Can't hurt. I will also have 20amp push button circuit breaker between the relay and the isolater. The wire used to go to each battery and the Alternater will be 4 gage. The short connection to the main battery will have 80 amp fuse protection. The longer connectin wire to the 2nd battery 100 amp fuse protection. All this seems to be a secure way to do this install?...thanks for the advice
Old Sep 17, 2015 | 04:27 PM
efaz43's Avatar
Thumbs up I replace the isolater I had with
A stronger one. It was 120 amp rated and the new one 140 amps. Anyone interested in the old one? $17, add $3 towards the shipping(@ $9) and its yours
