6th Gen ('00-'05): I put in a new radio and subs now my car won’t crank.
I just put in a new radio and subs in my 2002 Monte ss. Everything went in fine we had too cut the wire harness an wire it up. We followed the diagram we found too the dot. The car won’t crank or anything it don’t try too turn over or anything. I’ve tryed the relearn with the key for like an hour. When this first happened I tryed that and then I did the battery disconnect for 30 min too a day and still nothing. I’m replacing the bcm right now. I’m just hoping you guys might have any other ideas. I really want me car back lmao
Gm runs some maint functions that passes through the radio as well as car alarm in some cases. That is why i was told most people run a system off the factory radio. Otherwise they say you have to parallel the factory radio under pax side or in trunk. Ive heard. My buddy did radio installs for best buy back in the day.
Aftermarket stereo installation
6th Gen ('00-'05): After Market Radio Help
02 Earnhardt Monte Carlo SS
01-21-2015 09:59 PM
6th Gen ('00-'05): Battery short/ aftermarket radio won't work inside car
DJTJ
07-31-2013 05:13 PM
benh911f
06-19-2011 03:26 PM
