How to replace PCM in 2002 MOnte Carlo
Are you replacing the engine with same? Or are you upgrading to a super charge? If you are staying with the same engine, 3800 series 2 naturally aspirated, then all you should have to do is the relearn procedure. If you are going with an L67 or L32 then you would need to get the original PCM for that particular engine. Keep in mind that the transmissions for the L67 and L32 differ from the L36, 3800 series 2 N/A, so if you do an engine swap, do the engine and trans from the donor car (to include the PCM/BCM)
Blown pcm.
My 2004 Monte Carlo SS Supercharged was jumped by my son while I was away by a Golf cart with six batteries in series. My dashboard odometer reading stays lit while the car is off,my ABS and Traction Control light stays lit while driving, and the AC blows hot air unless I disconnect the battery for 5 min. and then re-connect it.Did he Blow my PCM or BCM or ECM, or are all three the same but just named differently.
I have a 2004 Supercharged,and it was jumped by a golf cart with 6 batteries in series while I was away, a few fuses were blown,my ABS and Traction Control light say lit and my AC blows hot air unless I disconnect the battery and re-connect it.Which unit do you think was damaged,the PCM, ECM or BCM or are these three the same but just named differently.
Unikardo
10-21-2014 10:58 PM
Nightmagic11801
13
02-15-2014 11:30 AM
6th Gen ('00-'05): To replace or not to replace Fuel Pump Module?
Chris s
01-29-2013 12:11 PM
Top_Notch
02-08-2007 02:10 AM
