How tO do a burnout
For starters you are going to completely ruin your already weak transmission doing this kind of stuff.
Not to mention ruin your tires.
On the topic of tires, they might be too good. These cars only send power to one front wheel, and they are heavy. Burnouts are not "easy" with a stock car on dry pavement.
To do one you need to keep your left foot on the brake, and give it a good amount of gas until the brake almost can't hold it anymore, then let go of the brake and go full throttle.
If you are just setting the parking brake and giving it throttle you won't ever get a burnout.
chibi has a great point these trannys arnt the toughest and doing a burnout is just asking for trouble...make sure you trac control is off and pavement a little wet ....i would suggest not to do it cause a tranny rebuild is like 2000.00 dollars and up so would it really be worth showing off one time??
All I really have to do is stomp the gas from a dead stop. I agree with what others said, I'm not sure it's really worth ruining your car for but you just have to practice the brake gas method chibi mentioned. Just lighten up on the break and keep giving it a little more gas till it breaks loose. It's also not really worth the careless or reckless driving tickets.
I just mash the gas, lol.
Once you build up your Monte a bit, instead of not being able to do a burnout when you're trying you'll start doing them on accident like this: Procharged Monte Carlo second try 0-60 (fail again) - YouTube
