Info: How can i figure out which fuel injectors i need?
Old Nov 25, 2019 | 11:08 AM
DunSun's Avatar
Default How can i figure out which fuel injectors i need?
I have a 97 Monte Carlo ls and I'm trying to figure which kind of fuel injectors I would need to replace my old ones? How would I go about figuring that out?
Old Nov 25, 2019 | 01:14 PM
Is there a specific reason you want to replace them all? They aren't typically just routinely replaced.
With that said, I would just jump on rock auto to grab the stock part numbers and then go shopping.
Old Nov 25, 2019 | 01:27 PM
DunSun's Avatar
my grandfather is a mechanic and suggested that I should replace them all since I have now knowledge of the last time they may have been replaced. I checked rock auto and they have a few but I'm looking to buy them in a set .
Old Nov 25, 2019 | 03:08 PM
Yeah but unless you are suspecting an issue with them, I wouldn't bother. Are you knocking or misfiring because one isn't spraying? Are you running too rich because one is stuck open?
At least you have the Part # now, you can look around on the web for a set then.
Old Nov 25, 2019 | 04:32 PM
xpage's Avatar
you can always send them off to get cleaned professionally, it's about $15 per injector for them to clean and flow test before and after the cleaning.
Old Nov 25, 2019 | 10:28 PM
I agree with Chibi. I never once heard of routinely changing fuel injectors. Between friends and family, many of us have had injectors out live the car at over 200K miles. I have only changed injectors if it is found defective or I broke one once getting the fuel rail out (and I replaced it with a junk yard one).
Old Nov 26, 2019 | 08:36 AM
Jeffs02rwdSS's Avatar
I agree with both Chibi and the Maniac. First thing I'd do is Ohm the injector with a multimeter for resistance and compare the values. If one is bad the numbers will be obvious and in the end probably save you $300 -$400 in parts alone. Good luck.
305chevydriver
Oct 12, 2015 10:02 AM
12cemudd
Feb 19, 2015 06:16 AM
davidcope
Jan 2, 2015 10:42 PM
malletboy
Oct 9, 2010 12:13 PM
malletboy
May 20, 2006 10:30 AM
