Homelink Temperature Way Off
Old Mar 5, 2014 | 10:00 AM
Dubstepticon's Avatar
Default Homelink Temperature Way Off
Been a while since I created a new thread here, but expect plenty more of them come spring.
So the temperature reading on my Homelink was 140*F on a cold winter day. It still isn't giving me correct readings. It might say 60* when it's only 40* out. It's all over the place really. Something is obviously wrong with the thermostat. How can I fix this?
Old Mar 5, 2014 | 10:19 AM
It should be the ambient temp sensor in front of the radiator. Maybe it is unplugged? Fell off where it is supposed to be mounted? Just needs to be replaced.
Old Mar 5, 2014 | 10:29 AM
Where exactly is the ambient temp sensor behind the radiator?
Old Mar 5, 2014 | 10:44 AM
Hopefully this helps. I'm nowhere near my Monte to show a real picture
Old Mar 5, 2014 | 12:03 PM
It's easy to find the sensor. You can work with it from up top or underneath. To go from up top, remove the long plastic shroud cover. Chibi's diagrams are spot on. It's a small sensor.
Old Mar 5, 2014 | 08:20 PM
Is it the thing attached to the wire in the picture?
Old Mar 5, 2014 | 09:54 PM
In the pic, it's item #1. When you look for it, it's a small black plastic sensor that should be held in with a plastic pin.
Maninblk
May 21, 2020 12:13 AM
Stencil
Feb 6, 2014 09:00 PM
rayray
Feb 2, 2011 04:50 PM
monte carlo 3831
Jul 9, 2009 09:03 PM
kweef
Dec 11, 2007 12:40 AM
