Help Please
Old Dec 23, 2014 | 08:26 PM
Alpha87's Avatar
Default Help Please
I have a 1987 Monte Carlo and the ignition is stuck in the on position and will not turn so my car is running (the key is also stuck too) and I can't turn off the car how can I turn the car off safely. Thanks in advance
Old Dec 23, 2014 | 08:42 PM
I had this happen before and I moved the steering wheel back and forth a bit and also moved the gear selector to make sure it was actually in park. Not sure which of the two things worked (probably moving the wheel) but I was able to turn off my car and remove the key.
Old Dec 23, 2014 | 08:57 PM
Alpha87's Avatar
I moved the wheel went through the gears and still nothing
Old Dec 23, 2014 | 09:05 PM
Try locating the ignition fuse in the fuse box and removing that. Should at least shut the car off.
Old Dec 23, 2014 | 09:49 PM
Have you tried shutting it off in neutral?
Is it a floor shifter or a column shift?
Heres some suggestions I found..
http://www.montecarloss.com/communit...&Number=409229 <-------Clicky
Old Dec 23, 2014 | 09:52 PM
Alpha87's Avatar
Finally got it shut off by disconnecting the coil wire had a family friend come he said the ignition is shot.
Old Dec 23, 2014 | 10:02 PM
Read my above post...
Its probably..NOT ... the ignition...
chevyONmine
Aug 1, 2023 07:33 AM
86monte carlo
Feb 9, 2012 07:46 PM
77gp
Jan 7, 2012 02:04 PM
Emnasty600
Jul 8, 2011 07:17 PM
