Hei dist swap
Going from a stand alone coil and distributor to a in cap coil hei distributor. My question can I use the positive coill wire on the coil from the stock coil to the BAT terminal on the distributor. Does this wire go thru the ecm or to the fuse block. Any help would be appreciated. Thanks John
Visceron
Jun 19, 2010 06:01 AM
