Hei dist swap
Old Dec 5, 2020 | 04:58 PM
Ubowl's Avatar
Default Hei dist swap
Going from a stand alone coil and distributor to a in cap coil hei distributor. My question can I use the positive coill wire on the coil from the stock coil to the BAT terminal on the distributor. Does this wire go thru the ecm or to the fuse block. Any help would be appreciated. Thanks John
nikk2themax
Nov 19, 2013 04:56 PM
l67ss
Oct 20, 2013 11:34 PM
04LaVaSS
15
Jan 16, 2012 10:25 AM
wht02monte
Jul 31, 2010 12:38 PM
Visceron
Jun 19, 2010 06:01 AM
