6th Gen ('00-'05): Heater fan turns on and off when I hit a bump or shut the door
Old Nov 10, 2018 | 04:51 AM
Junglelarry's Avatar
Default Heater fan turns on and off when I hit a bump or shut the door
Just purchased '04 Monte and the heater/air fan is only occasionally running (barely at full setting), it turns on and off if I hit a bump in the road or shut the door. It will run for awhile if I sit still, but if I hit a bump then the fan cuts out, and may not start up until I shut the car off and start it back up (and shut the door) Any help? Thank you!
Old Dec 26, 2018 | 05:35 AM
ETbME's Avatar
If you haven't already fixed this, it sounds like you need a new blower motor resistor module. They're easy to check before you replace.
98Z34
Apr 2, 2014 07:36 PM
Team Goofy
Jan 6, 2012 07:54 PM
sparkyallen1
Mar 11, 2010 11:48 AM
captaindamnit
Jan 4, 2010 05:08 PM
zipsayain
Jun 25, 2008 08:58 PM
