headlight switch
Old May 16, 2012 | 11:05 PM
1SLOWSS's Avatar
Default headlight switch
so when my car is off my switch works just fine,, pull it back once and parking lights come on pull all the way back and headlights come on
but when i start it, i cant ever get the head lights to go off day or night is this normal?
im about to get my HID kit in and just want to get this figured out b4 hand thank you in advance
Old May 16, 2012 | 11:16 PM
is it the highbeams that stay on? The DRLs will stay on.
Old May 16, 2012 | 11:33 PM
1SLOWSS's Avatar
The DRLs will even stay on at night?
Old May 17, 2012 | 12:25 PM
1SLOWSS's Avatar
its the lights on the outside..
so i went ahead and bent the #87 prong on the DRL Relay and the lights still stay on.. is this switch broke? or am i missing something about this car.. haha thanks for you help
Old May 17, 2012 | 12:37 PM
aussiek2000's Avatar
High beams will come in in daylight no matter what position the switch is in. Low beams come on when the ambient light get low enough. If you bent pin 87 on your 2001, your lights will be stuck on. This trick only works on 2005 models.
Old May 17, 2012 | 01:26 PM
1SLOWSS's Avatar
haha ok so its not the switch.. i dont understand why there is a switch then if you dont ever have to use it why have it?
thanks for you help
edit: and the lights are always stuck on anyways...
Old May 17, 2012 | 02:37 PM
Franks 03SS's Avatar
2011 Monte Of The Year
its probably your ambient sensor on top of the dash when i bought my monte it was knocked inside the top dash piece and just placed it back and all was good
Old May 17, 2012 | 04:17 PM
DRLs are on the outside of the car....
x2 to this... they seem to be covered or broken quite often with these cars
Harlan2012
Feb 6, 2013 01:39 PM
rolandemartinez
Oct 2, 2010 02:17 AM
matrx10503
Aug 25, 2010 03:12 PM
VinceF99
Oct 14, 2009 10:13 PM
Yellow_Monte
Apr 26, 2006 03:24 PM
