Is this headlight switch pic causing low beams not to work??
Old Jun 20, 2010 | 09:28 PM
rolandemartinez's Avatar
Default Is this headlight switch pic causing low beams not to work??
Hello all.... Question my low beams went out at the same time on my 00' monte carlo, I pulled the headlight switch off and took some pictures.All my other lights are fine. One of the pins is burn't... I just wanna make sure thats what it is causing it because that switch is over $100.. Any help is greatly appreciated, thanx
Old Sep 29, 2010 | 03:55 PM
Pure2sin's Avatar
You can get the switch for less off Ebay if you still need it. Just type "Monte Carlo headlight swtich"
Old Oct 1, 2010 | 06:21 AM
labnjab's Avatar
That would do it. I would also make sure your headlight sockets are not melted too because something caused the switch to melt and its usually a bad connection somewhere or something drawing too much. Just don't want you to have it happen again.
Old Oct 2, 2010 | 02:17 AM
I'm not sure if its possible or if it will help, but did you try to clean it with some electrical contact spray?
svzpt71
May 11, 2015 06:30 PM
Ballerz138
Dec 7, 2013 09:48 PM
NYGiantsfan
Dec 9, 2012 08:04 AM
KWJR86
Apr 21, 2010 08:27 AM
mickey
Mar 20, 2008 06:15 PM
