Head problems
Old Dec 9, 2018 | 05:38 PM
Default Head problems
Is there a way to check for a cracked head rather than a leaking gasket?
I have an oil leak ( i suspect from the head gasket) but its only leaking when the car is running and its significant.. Half a quart in about 1 hour's worth of driving..
I can see its NOT coming from the valve cover and theres no oil on the rear header.. There IS oil on the on the trans and from there its leaking onto my downpipe.
What else should I check or any other advice anyone has? Thanks much!
Old Dec 9, 2018 | 07:42 PM
Jeffs02rwdSS's Avatar
A possibility , lower intake end gasket ( China rail) could have split I believe you have a 3800 so won't suggest distributor o ring . If a valve seal failed it could create extra pressure inside engine but think you would see smoke out tailpipe. For a external leak maybe try a inspection mirror and flashlight or a oscilloscope if ya can find one. Good luck
Old Dec 10, 2018 | 06:13 AM
Something else I noticed this morning.. Watching my vac/boost gauge its going back and forth from -16 to -20.7 over and over during idle.. 20.7 is what it sits at, at idle..
I am getting the drops of oil when the gauge goes to -16psi... Oil stops when the gauge goes back to -20.7 then starts again when it drops to -16. Over and over...
Old Dec 10, 2018 | 09:06 AM
Still guessing here . the way I'm reading your symptoms is when you're losing vacuum from 20 down to 16 is when the leak is occurring. Only 2 things that come too mind are Pvc and Egr that create vacuum leaks while engine is running. Not exactly sure if the SC version uses both or not. Also on the lower intake where the Egr tube enters the intake would be another place to check.Once again these are guesses , the 3800 on my Pontiac don't have a SC too reference everything. Good luck
Old Dec 10, 2018 | 06:50 PM
Malcolm Fay's Avatar
Check the oil pressure switch by the oil filter.
Old Dec 11, 2018 | 06:04 PM
Ok so it ONLY leaks when the car is running.. Not coming from anywhere by the oil filter.
Seeing as I was WOT moments prior to this leak starting....
What im getting is oil pan gasket, valve cover gasket, or timing chain cover/gasket are the possibilities.. (From a quick google search)
Other than needing to repair one of these, is there anything I should consider..? I drive this car normally like this...
Old Dec 13, 2018 | 05:49 AM
Are you running the stock Pvc system or have you changed it and put breathers in the valve cover ? I have seen people put breathers on before and they don't realize the crankcase system is suppose to be in a vacuum. Just throwing another idea out for you. Good luck
Anonemu
Nov 6, 2017 01:08 AM
farmerjg
Jun 8, 2014 07:41 PM
bagged2drag88
Feb 20, 2011 07:43 PM
prez
Jun 6, 2009 11:41 AM
cbrackin
Aug 21, 2008 11:53 PM
