has anyone got this from ZZP
Old Apr 25, 2011 | 11:45 AM
Blazed SS's Avatar
IT HERTZ
Default has anyone got this from ZZP
ZZ Performance
I wanted to know if any one here has installed this and if it works ?
I am thinking of getting the stage 1 for my wifes car
Old Apr 25, 2011 | 12:14 PM
nitehawkjcb's Avatar
Looks like an alternator voltage booster. It only raised my voltage by like .1 or .2 (they said it should raise it by like .5), so I say it isn't worth it
Old Apr 25, 2011 | 12:37 PM
Wilco's Avatar
I got one installed. First of all, be very, very careful with the connectors, specially the one plugging into the alternator. The wires can easily become detached. The adapter raised the car's voltage by about 1v, nothing spectacular, but it helps if you recheck the engine bay's grounds, replace the alternator's wiring with 4 gauge (if it's not already) and add the big three to the car's electrical system. Of course, these steps are only for cars with serious voltage drawing stereos systems in them. If your wife's car doesn't have one I wouldn't bother buying the adapter.
Blazed SS's Avatar
IT HERTZ
copy man thank you !!
Old Apr 25, 2011 | 12:42 PM
i got one, and it was stage 3 off clubgp, i think it raised around .5
Blazed SS's Avatar
IT HERTZ
my wifs car (2004 Pontiac grand am gt-1 ) has a stock alt and she is running a single 10 and 1000w RMS between the mids and highs and the sub I thought it might be essayer than doing the big 3 on her car to get some easy power but as all ways if it it to good to be true it probably is it sounds like on this one
Old Apr 25, 2011 | 12:45 PM
Blazed SS's Avatar
IT HERTZ
copy the wifes car is like 13.3 v I was trying to get her closure to 14 v
Old Apr 26, 2011 | 12:13 AM
You could try the voltage booster, with an alternator re-wire also you should be close to 14
Old Apr 26, 2011 | 09:06 AM
Blazed SS's Avatar
IT HERTZ
that is what I have done with the Monte I am o Gage big 3 and a high output alt and I just don't know if her car is worth all of that LOL
Old Apr 26, 2011 | 03:19 PM
As long as it doesn't go lower than 13V she should be fine - other options include an overdrive alternator pulley...
zipper
Jun 1, 2015 07:50 AM
Tzarm
Aug 4, 2010 08:56 AM
God_Bot
27
Apr 10, 2008 04:50 PM
04MonteLS
Jul 19, 2006 12:09 AM
