anyone try these zzp bulbs?
Old Jul 20, 2010 | 06:45 PM
Tzarm's Avatar
Default anyone try these zzp bulbs?
http://www.zzperformance.com/grand_p...d=94&catid=101
I've been tempted to get them but id need the combo since my Monte is an 04 but I thought I would ask here first since I browse around quite a bit...so anyone have any experience or recommend a nice set of bulbs with that nice blueish tint to them for a decent price?
edit: sorry if I posted this in the wrong place on the forum, I wasn't sure where to put it
Last edited by Tzarm; Jul 20, 2010 at 06:47 PM. Reason: not sure if this is the right spot or not in the forum
Old Jul 20, 2010 | 06:50 PM
GrandPaDave's Avatar
I once used xenon bulbs. The heat melted and fused my harnesses and created a fire danger.
Old Jul 20, 2010 | 07:00 PM
i had xenons once, i would just get hids, spend the extra bit to get the better bulbs
Old Jul 21, 2010 | 06:02 AM
nighthawk626's Avatar
back away from those man. they could F ur headlight housing up. if you want bright N SAFE go with real HID
Old Jul 21, 2010 | 08:04 AM
I would just get silverstars or silverstar ultras. They appear to be expensive, but if you shop around you can get a set for $20
I moved your topic to the general tech spot, since detailing is more for cleaning the car
Old Jul 21, 2010 | 08:09 AM
Depends on what you're wanting them for. You want them for the look of hte headlight, or for visibility. Ebay has some colored ones taht dont get too hot. Its not a deep color, just a little tint. I used somthing similar befor in my monte and didnt have a problem, BUT and a HUGE BUT, they were not 100W, they were 60W
Old Jul 21, 2010 | 10:59 AM
RickAKATed10's Avatar
Photobucket
Ditto.
Old Jul 21, 2010 | 01:31 PM
I just got a pair of silverstar ultras on amazon for $25 for the pair!!!!
Old Jul 21, 2010 | 04:00 PM
Tzarm's Avatar
sweet, thanks for the advice and i'll check into those silverstar ultra's
I don't mind spending a bit of money for a nice look to them, I would like to get a set for my low beams and high beams but i'll definently shop around for those silverstar bulbs and check which ones will fit my 04, thanks again
edit: i found this post by searching around
2003 CHEVROLET Monte Carlo
Low beam headlamp
9006
9006SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9006ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9006EB EcoBright - Your Environmental Choice
9006XV XtraVision Halogen - The Brighter Light
9006CB Cool Blue Halogen - The Whiter Light
High beam headlamp
9005
9005SU Silverstar ULTRA for Ultra Night Vision - The Whitest and Brightest Halogen
9005ST Silverstar High Performance Lighting: The Whiter and Brighter Halogen
9005EB EcoBright - Your Environmental Choice
9005XV XtraVision Halogen - The Brighter Light
9005CB Cool Blue Halogen - The Whiter Light
think those would be the same as an 2004 SS? Im assuming it would but I want to double check first
Last edited by Tzarm; Jul 21, 2010 at 04:08 PM. Reason: adding more information without replying
Old Jul 21, 2010 | 05:13 PM
Yes they will work 2000-2005.
