Had to pull fuse to get lights to shut off!!!
Old Mar 9, 2010 | 08:04 AM
Tomofnnh's Avatar
Default Had to pull fuse to get lights to shut off!!!
2002 Monte Carlo Pace Car (728 of 1100)
3.8L V6
86,000 miles
here's what happened:
* security light came on while driving (twice now)
* lots of clicking under dash from both ends
* volt gauge drops to zero
* headlights remained on after car was parked.
I had to remove the CLSTR/BCM fuse just to get my headlights to shut off. I reinstalled the fuse this morning (heard more clicking), but now it seams fine.
Also, my car pops door lock fuses within 2 weeks if I was to install one.
Any thoughts? Pinched wires? dieing computer?
Very similar to this guy... http://www.justanswer.com/questions/...s-on-only-when
Old Mar 9, 2010 | 08:11 AM
Typically when you have problems with the Passlock system and electronics acting weird, you have the signs of a BCM starting to go, which unfortunately is an expensive fix and the dealership will have to help you because they need to do the programming.
Old Mar 11, 2010 | 01:44 PM
Tomofnnh's Avatar
New BCM on the way ($520)
Hopefully it fixes my rear window defrost and popping door lock fuse.
Old Apr 23, 2010 | 12:11 PM
Tomofnnh's Avatar
Well, having the BCM replaced cured my popping door lock fuse (see ya later 2-year old problem!!!)
Furder2010
Feb 14, 2012 08:34 AM
chamberz
Jan 17, 2011 09:30 AM
cali2000ss
May 1, 2008 10:42 PM
rob559
Feb 22, 2007 11:13 PM
thatyounginss
Oct 30, 2006 08:00 AM
