Should a fan still run after the car is shut off?
Old Feb 24, 2011 | 02:55 PM
Furder2010's Avatar
Default Should a fan still run after the car is shut off?
I made a post about the temperature gauge not working (it started doing this a couple of days ago, it just stays below the line and doesn't register anything), but the shop said it was the cluster so I found a guy to repair it.
However, I noticed that a fan runs under the hood even after I turn off the key...I remember reading about something like this somewhere on the forums but I can't seem to find it again.
Should the fan still run even after the car is turned off? Is the temp gauge not reading a cluster issue?
2000 Monte Carlo ss 3.8
*EDIT* It is reading the following codes:
DTC P1404 Exhaust Gas Recirculation (EGR) Closed Position Performance
DTC P0141 HO2S Heater Performance Bank 1 Sensor 2
DTC P0404 Exhaust Gas Recirculation (EGR) Open Position Performance
DTC P0128 Coolant Thermostat
DTC P0141 HO2S Heater Performance Bank 1 Sensor 2 (Yes, it read the same code twice)
Old Feb 24, 2011 | 03:37 PM
If your car doesn't know the proper temp reading, as a precaution the fans will stay on for like 3 minutes after shut off I believe
Old Feb 24, 2011 | 03:47 PM
Furder2010's Avatar
So what does this mean? That the t-stat (which is thermostat, which costs like $10 right) is bad and needs replaced? Would that cause the gauge to not read anything on the cluster?
Old Feb 24, 2011 | 04:28 PM
biggriggs's Avatar
If you have the 3.4L engine, then that is exactly what it means. The PCM will go into a failsafe mode which disables the temp gauge, disables the a/c clutch, and sets the fans to be always on (including a few minutes after the car is off).
Old Feb 24, 2011 | 04:42 PM
I had this happen on my 3.4L in 2001 Impala ,gauge read funny ,relace fan relays temp sender, .... fixed my problem when changed thermostat
Old Feb 24, 2011 | 04:51 PM
Furder2010's Avatar
It's a ss, so the 3.8...what does PCM stand for? Do you still think it's themostat?
Old Feb 24, 2011 | 04:53 PM
Takes 10 minutes to swap it out and check.
Old Feb 24, 2011 | 05:06 PM
Enzo354's Avatar
STILL SLOW
Its the t stat...
Old Feb 24, 2011 | 05:11 PM
Furder2010's Avatar
I can't find the how to for fixing the thermostat on a 3.8L...can you guys point me in the right direction? Sorry for being a bother, I really appreciate your help
Old Feb 24, 2011 | 05:28 PM
Pop the hood, take the engine cover off. Remove oil filler neck and cap, lift up and pull forward, replace oil filler neck and cap.
Follow upper radiator hose to Thermostat Housing, remove the 2 screws (wrap a towel around the housing) and there's the thermostat. Insert new the same way, replace housing cover, bleed system, possibly top off coolant (not much should come out) and your done.
