GTP brake booster for CarTuning turbo'ed 03 SS
Somebody either told me or I read somewhere that using a brake booster from a GTP in my SS would help prevent false knock readings and possibly work better in a boosted situation.
My brakes currently work fine, however, the transmission fill tube, even after massaging it a bit, looks as though it could be a culprit in some of the knock readings I have been getting.
I don't have one handy to do a direct comparison unfortunately.
I know somebody said something about it but I can't remember who or where.
I guess senility is setting in sooner than I would like.
Anyway I just thought it was worth asking.
Y'all take care
Y'all take care
The other thought process is that possibly there is a better control over the the action of the break booster when the car is under boost. Now I'm highly skeptical about that since the booster is vacuum powered but it is an entertaining thought.
In an F body that I had before I ended up using a booster out of a truck that was powered by the power steering pump. Worked really well. That has bee quite a while back.
I guess I didn't state the situation clearly.
sorry.
Thanks
"Actually you have it backwards. The Monte/Impala booster is the ones the guys use in the GTP's for more clearance as it is a touch smaller."
oops. well i was close.
take care
Latch
Apr 17, 2009 10:48 AM
blue02SS
Jan 24, 2006 09:17 AM
