got marshmallows?
I have a 1995 monte carlo that must have had a curse put on it.... ok I replaced theengine and now as soon as it warms up it shuts off sometimes it strarts right back up other times you need to wait a few minuites also it usually only runs a few mins at most b4 shutting off again it is annoying me as i would love to have the car done so i can use it thanks brian
how long ago did you have the engine put in??i know its probably just a sensor or something...but if it was recently the shops work should be warrantied
ok i replaced the coil packs / ignition module and that fised the problem thank you i was also wondering if you knew why when i start my car the idle slowly climbs to 2500 rpm's but if i shut it off and restart it the idle will b at 1500 which is also high thanks
cornerview
Vendor for sale section
May 4, 2013 07:43 AM
jimmytammy
Apr 25, 2013 05:41 AM
mickey
14
Oct 6, 2005 04:13 PM
